Install Advice
You have 3 sets.. Front.. Rear.. and Sub. You will only be using Front and Sub , unless you decide to amp the rear speakers for the passengers.? Do like 25-watts rms to those. You will or should have enough Speaker wire left, and I chose the 4 ch RCAs for future use on 4 ch as the amp kit has one set that can be used for sub amp
You stated at the beginning that you have this HU so it should not be an issue. You are not doing anything with the Steering controls. It stay the same.
Yes that's what I have. I'm not sure why they have those on there or what they do. I think I'll amp the rear speakers as well. Which app do you recommend for those id like to keep the 2 amps the same brand. Unless there's a big price difference will 0 guage power connect to a smaller amp?
I can vouch for both 4 ch amps.. I can only vouch for the 700,1k,and 2k and 4ch CT Sound amps. I have not used any Avatar Mono amps yet. The 0 ga is the MAIN supply wiring from the battery to the Fused Distribution block to reduce to the 4 ga to amps
What wattage would you recommend for the 4 speakers?
Ok. If you buy tweets they’ll come w their own inline crossovers. Youd connect the speaker wire to the crossover which then connects to the...
930
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
611
Chris04626
CarAudio.com Recruit
Chris04626
Maine
Chris04626
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
