Brigded channel question
  • 2
ashtrey
17
USA
Can I hook up two 4 ohm speakers wired parallel to the brigded channel? Wondering cause it doesn't show that on the page and is it safe to assume it would put out roughly double the listed power or somewhere close
screenshot_20231205-114525-png.54983
You cannot unless you wire the two speakers in series. If you wire them in parallel, that brings the load down to 2 from the speaker and the amplifier sees half that in bridged mode and will be operating at 1 ohm. It is rated only for 4 ohms bridged (essentially working at a 2 ohm load). If you're going to use this amplifier, you should wire the two 4 ohm speakers in 2 channel mode only.
161
393
10
788
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
450
ashtrey
ashtrey
USA
