Need an advice, for Sub and Amp connection
  • 2
Adel
Germany
I just got Pioneer GM-D8701 rated as follows:
300 rms @ 4 ohm
500 rms @ 2 ohm
800 rms @ 1 ohm
And I got the Pioneer TS-D12D4,
DVC 4 ohm each
rated 600 watts
So it can be connected as 4 ohm , but in this case the amp will deliver only 300 Watts.
What is the best combination for sound quality, I don't care about spl , I like tight bass.
Thank you all.
If your sub is d4 your only real option is to wire in parallel for a two ohm load.
Thank you for your reply.
What if I wire in series for 8 ohm load ?
Sorry for my newbie questions, but wouldn't it have better sound quality (tight bass) but with less power? Cause I tried the model with 2 ohm dual voice coil and bass was boomy connected at 4 ohm.
501
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
608
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
892
Adel
Adel
Germany
Adel
just call me KeV
just call me KeV
